I have a leak and I thought it was the wheel cylinder. Threw a new one on and that didn't fix it. Un-did the fitting on the wheel cylinder and inspected the flare and thread and it appeared to be fine so I put some thread sealer on there and still no luck. I "wusabe" tightened the fitting for my last solution and no luck there either. Could it be a jacked up flare that just won't seal or did I happen to get another bad wheel cylinder? BTW, I changed both sides and the other side is good. Any other things I could do before I throw a new line on there? Any way I can get a pre-bent line?
TIA,
TIA,
