Rearend Chatter
wilkinsde
I recently had the rearend bearings replaced with the ring/pinion gears setup. On the way home from work today I noticed some rearend chatter when slightly accelerating from a stop and in a turn. Do you guys think the mechanic didn't put the posi-lube in, or could there be other issues here? Thanks for any advice.
Put some limited slip additive in. They prolly did forget.
I agree, get two bottles. Mine still did it after one and a couple weeks to soak in and dozens of figure eights in an empty parking lot. I put in the second bottle and chatter was gone.
