the second pic
one is for 60# 107 octane
should have higher timing (maybe 22-23degrees) and fuel (injector duty ) for 22-23psi or so
second is for 60# inj and 93 octane , should have fuel for 15-17psi or so and timing should be around 17-18 degre
but theres no way to know what the turbo or hp level (ported heads) that was meant for , could be for stock or ported heads,and for stock turbo or a 70 turb0 as that would require a different injectory duty because hp would be significantly different , since those chips arent adjustable your fueling could be too much or not enough fuel at wot and noway to tune the amount it could be off
