remove door lock
jim0207
INVNO1
I have factory alarm. I want to remove the door lock. The C clip is holding the cylinder. My question is the electrical connection involved with C clip?
Once you remove the rod clip there is a ring that goes around the lock cylinder it has two wires attached to it. Then there is the lock cylinder which is held on with the big clip.
To answer your question there should be a wire in the c clip if I remember with a rubber boot.
You have to remove the small c clip on the end of the lock cyl. Yo remove the wires. Then the large c to remove the a
