Removing front swaybar...have questions
WSLN 6
Powered by Murphy's Law
If I am at the track can I remove or loosen the driver side endlink on the front swaybar to achieve better 60fts or do I have to remove the swaybar completely?
Would you damage the endlink by just loosening it?
I removed the swaybar last year and had improved 60fts, but the car handled like a wet turd.
You can loosen it up and you will get most of the benifits of no swaybar at all, except for the 25# weight reduction. A drawback with loosening it up, though is you can forget to tighten it back up and the nut and bushings can work loose and fall off to be lost forever. That has personally happened to me.
If you put 2 air bags in the rear it won't be that bad with no front sway bar. ;) Without the front sway it sure lauches better:D
