Replacing header bolts - options?
6SENSE
I would like to use new header bolts, what are my options? Does ARP make a set for TRs? Or should I just match up some grade 8 bolts at the hardware store?
Any suggestions are much appreciated.
I don't believe ARP sells a kit for our cars but you may be able to use find some SS studs that will work.
Not sure what the OEM hardware is made from but I would not use grade 8 bolts myself. The exhaust is subjected to very high temperatures that maybe better suited for SS hardware.
Just one persons opinion.
