I have a steering problem with my 87 T. The wheel has a good 2 inches of play in it before I get any steering response whatsoever. I replaced the steering shaft and no difference. I decided to check the front end. When holding the wheels at 9 and 3 and moving back and forth, the centerlink moves. Im assuming this is the problem. Ive decided to replace the centerlink and idler arm together, does anyone have any tips for the job? Havent done either before, but they look pretty straightforward. I know Ill need a pickle fork and a hammer to separate the joints, is there any other trick to the job?
