Nov 3, 2001 #2 JayC T6P.Com/TB.com Administrator/Webmaster Staff member Joined May 27, 2001 Messages 9,499 If the idle is raised, it would be a good idea although you could probably get away with not doing it.
Nov 4, 2001 #3 T Turboaddict Guest when resetting the iac, do you really have to disconnect the IAC connnector and adjust the IAC counts? Can't you just set it by playing with the throttle screw?
Nov 4, 2001 #4 JayC T6P.Com/TB.com Administrator/Webmaster Staff member Joined May 27, 2001 Messages 9,499 You need to set it as per the instructions on gnttype.org except I would bump the idle up some if youre using a chip that has a raised idle.
