Ok ive been trying to solve a rich condition since last year. Ive lowered the fuel pressure, changed the o2 sensor(4wire ngk), and checked every possible vacuum/exhaust leak on the car. Nothing changes the richness. I get about 8-10mpg and the cat smells like rotten eggs. The cat is brand new and its not plugged. Under slight throttle i have a pop out of my tailpipes. My plugs are gapped at a tight .35 and they are cr43s. All of my scantool data is right on. BLM and INT are where they are supposed to be IAC is at 22 and TPS is at .42. O2 cross counts good. Yesterday i pulled number 6 and noticed it smelled like gas and was a lil moist. I put a FP gauge on the rail to see if maybe i was leaking. Pressure holds just fine. What else causes gas on a plug besides a leaky/stuck open injector?? Is there another way to test the injectors? Could the popping be my coilpack? Help before i take a sledge to the car.
Dan
			Dan
