Easy to install and I backed the waste gate rod down to about 1/8 tension maybe a bit more and with the controller as received .
First test run carefully rolling into throttle watching boost showed 15 psi rock steady. Next run I adjust the controller 3 rounds and boost went to 17 I expected more.. I then adjust the waste gate rod about 3-4 rounds and boost went to 21 psi .i only had about. 3-4 threads left in the controller is why I gave up getting more boost that way. Boost is rock steady where with the stock system I might see a momentary 1 psi over shoot . I see no improvement in spool up then it came I'm quick already with the 2800 rpm stall. I left it at 21 for my first track runs early next month. I was at 23 with the stock system. Overall it works but I don't feel it was worth the $ in my situation at least right now.
