I have been following the different threads on cooling problems, and I was wondering if anybody had done any digging into different thermostats, specifically high flow?
I have a slight cooling problem, and have gone the usual route of RMI-25 and distilled water, stock 160 stat, bigger cooling fans and shroud, OD H2O pump pulley, etc. But noticed that not much has been mentioned about thermostat flow, just their opening and closing temps.
We have a pretty good flowing pump (10GPM at idle) to start with, and Flowkooler make a pump that flows about 20% more. But the size of our thermostat flow area, seems to be the bottle neck in our system. I know we are also limited by the size of our thermostat housing, but using what we have... A better flowing thermostat wouldn't hurt.
I did a little digging and came across a Robert Shaw stat, that flows a lot more that all the other stats. Digging in the garage, I found an old one that I had, and looking at it and testing it, it is easy to see why it flows more. The only problem is that it is off an old Mopar (too big) and is rated at 180 deg.
I know the Flowkooler site list one for our engines, but I have read that it doesn't fit. (Big board Archives)
Has anybody found the correct Robert Shaw stat for our cars? And have any comment's on it's performance?
Paul
Paul
