I've got my heads off to repair blown HG and wanted to replace the rocker w/ roller. I've seen where several of you guys have put them on and wanted to get the info on the swap.
First, what rockers did you use. Were they the 7/16" for the V8 Pontiac? If so, what did you do the the rocker bosses to except the 7/16 stud vs. the stock 3/8? Also, what did you use for a guide plate...how do you keep them from moving side to side? What about rocker boss height? It looks to me that the stock height will be too tall with the roller rockers installed.
Any info would be appreciated.
Kevin
Kevin
