Rough idle only in the mornings
TURBOV6
"SECRET PARTS"
Staff member
When it warm up or a few taps on the gas its fine. What could it be?
Rough Idles in mornings
My Car actually did that and what solved the problem was cleaning the iac, and checking the tps voltage.. After that, things were smooth sailing. If you're usoing the stock chip there hould be no problem there. Also checkthe maf to make sure its good too! Hope that helps...
