I posted a while back about my gn having a rough idle that was progressive until it eventually would not idle at all and would miss very bad under throttle. Advise I received was to check maf sensor. I installed a new maf sensor and the car would idle but not much change and still missed real bad. I checked the plugs and they where very black. Replaced plugs with UR5's. Car started and ran smoothe but after a few day's and starts it is starting to idle rough again except after it runs for a few minutes or increasing the throttle it smoothens out. I also noticed an almost fresh smell of gas while running( no leaks).. so im thinking a spark issue. Seems it's not burning the fuel correctly.. Coil pack Maybe.. Any suggestions... I don't have a scan tool(need one bad)... Thanks
