mongoosetoo
- Oct 19, 2005
My 85 GN powerplant in a Cutlass doesn't seem to want to accelerate. Idles fine, but fails to accelerate without popping and generally seems to have no power. Cmon I know this is only as hot-air engine, but it should still pull like a freight train.
Brand new engine, internal engine probs (like cam timing) are probably not the problem. But I'll pull a leak-down test and check compression - post later.
I have verified the vacuum hose routings.
The code my ECM says is 22 TPS low. I checked voltage at the center wire to ground: .42 volts at idle and 4.11 at WOT, so the TPS seems to be working - unless it's intermittant. I've got a new Holley one coming, but I don't think it'll do the trick.
Any thoughts? This harness was transplanted as well, I'll try to trace TPS wires back to thier source to look for breaks or shorts. In the mean time, if anyone has a reasonably priced Turbolink setup, I think I can get a better picture of what's going on. I have a laptop, I just need the software and hardwire hookups.
Thanks, Brew
Thanks, Brew
