Ok so I have had an issue with the way the car runs and idles for almost a year but little to no time to really get into it.
I have changed the coil pack, plugs, wires and MAF. Checked for vac leaks in every imaginable way thinking this was the issue to no avail. Engine was rebuilt by KDK and ran great for about 50 miles and this issue came up, like I said it's been about a year. I dumped the fuel this time and put stabilizer in the tank and the fuel filter looked good and pressure is at 40.
Issue is idle and when you first get on it. It idles very rough and sometimes dies after a few minutes once it goes closed loop, starting is never a problem.
When you smash the go peddle it will stutter and spit until it seems to adjust itself out with boost. When in boost no isses and will break the ass end loose at 40mph, no knock with 850 readings. Cruising speeds with a little throttle blip will sometimes make it studder, sometimes not but always in the 200-400 range.
039-100 at idle and sometimes 000. If you bump the throttle it goes up to 828 and then back down to 100's.
af 05
L8 38-40
bat 13.6
int 128
bl 125
clt 175
ats 100
r 725 - 900
tps .46
iac 20
cc 228
nal 34
Thanks in advance for any help with this issue as the car will become my "driver" when home for the 4 weeks a year I am home
af 05
L8 38-40
bat 13.6
int 128
bl 125
clt 175
ats 100
r 725 - 900
tps .46
iac 20
cc 228
nal 34
