I KNOW that I am asking for the impossible with as little info as I can provide but figured I would ask anyway.
Recently my T has been running warm at over 200 degrees. She never really ran over 180ish before.
Oil and coolant levels are fine so I haven't started chasing a blown head gasket and instead replaced the water pump with a HD unit, 160 degree thermostat, upper and lower radiator hoses. I have not replaced the radiator cap yet, but will be picking one up today and what appears to be an F body radiator has been flushed and looks to be pretty clean with no visible calcium or rust build up.
I have a Cottons FMIC which covers the entire radiator but have what looks to be an intrepid dual fan set up. I am also not sure on the wiring harness that controls the dual fans.
I noticed with the car idling in the driveway, the fans initially come on at 164 degrees and shut off around 162 (checking the scan master) keeping the temps in check. After a few cycles, the fans stop coming on and temps start climbing with no way to turn them on.
Does any of this sound normal or SOP for a dual fan set up? Is there a way to over ride the temp sensor switch that turns the fan on with a toggle switch?
Lastly, any other areas to check for a running warm car?
Appreciate any feedback as the down fall of purchasing a used car sometimes leaves previous modifications a bit of a question mark.
