Here goes...I have a 93 S-10, 2.8 liter V6 engine, 5 speed trans, 2WD.
The 02 sensor wire managed to mate up with the passenger side exhaust manifold and as a result the SES light come on. The wire burned in half before the plug. The code in the ECM was code 13.
So I reconnected the plug to the wire with a new piece of wire. Then i replaced the 02 sensor. At first I didn't disconnect the batt like I should have, so the code was in the ECM and the SES would occasionally come on and go out.
So one day I unhooked the batt neg side and let the truck sit for 24 hrs with no juice.
Hooked it back up and checked the ECM...no codes stored. (got a code 12...let it run thru the cycle)
Well now the SES light comes on again. It usually seems to come on if the truck is ran down a long stretch of highway. It will come on and stay on 1-2 minutes and go out again.
Recheck the codes...code 13 is in the ECM again.
On top of that, the mpg seems to have gone down from 20-26 to 15-17.
I want to unplug the 02 sensor and take a reading....can I do that? If so, what should it read? Where should I set my multi meter at?
What else should I check for?
Thanks.
Thanks.
