cutluse231
- Jun 10, 2001
I have my Regal with the 455 up and running.
I'm trying to get the lock up to work on my 2004R trans thats in it.
I've been to several sites for lock up kits, and a couple seem conflicting on their ways of being installed.
One ( B&M) uses speedometter readings to lock and unlock TCC, looks like a plug in to the female connector on the trans and a speed signal source is all thats required.
Another couple of sites ( Bowtie Overdrives, & T.C.I.) show removal of the trans pan for internal rewiring, one grounds the TCC solenoid to it's self the other uses an outside source for grounding, both bypass the 2nd and 3rd gear switches and replace the 4th gear switch with another that has 2 posts on it.
Both also controll lockup from the Neg side
My questions are... is it necessary to have internal wiring done?
Or can one run ign power to "A" on the female plug on the trans and have a ground coming out of "D" to ground with some type of switch or interrupter source for to unlock TCC?
Whats throwing me is the B&M kit and the one (if I remember correctly) from Art Carr both seemed to be plug and play with no internal mods.
Dont get me wrong I will go the extra steps to insure it works correctly and safely and get one of those full kits.
But if it really isn't necessary I won't.
Thanks again guys
Thanks again guys
