S2 valve covers
All of the Motorsports covers came minus holes..it's pretty common. You get to drill and put your own in. :p A good number of the circle track cars with dry sumps had a fitting in the rear of the manifold for the evap stage and the valve covers were sealed.
So, if I think I might need a set down the road sometime, this would be an "allright" set to try for?
I have a couple sets with extended breather tubes welded in place.50.00 a set.I can send you pics if you like.
I sure would like some pix!!! Thank you.
