Sail Panel Fabric question
nickygn23
I just changed out both of my upper door panels. See the "how to section".
Quick question before I tackle the real sail panel fabrics. Has anybody done it before? Any helpful hints before I go for it? I'm sure the rear seat comes out and the panel but if anybody has done it before please advise.
Literally just did this last weekend. It's pretty simple if you remove the back seat. There's a couple of "hidden" screws behind the sides of the seats that would need to be removed in order to take these panels off. The plastic trim by the door also needs to be removed along with the seat belt up top.
In addition to what Boston GN stated, once you get access to the panel you'll see that it's held in place with a single staple. Long and flimsy, but can be reused if careful in removing it. Good looking door panels!
Thank you for that info. I probably won't be reusing it. I bet I would have lacerated myself on it though. I have scars all over my hands from when I did the seats. Dang Hog Rings..... There is like 15 different things under our seats that will cut up your hands.
Thanks again for the heads up on the staple
