Scanmaster hooking up to PL
incharge
Ok guys I have hooked up my Scanmaster to the powerlogger and installed the new chip in the SM Everything is ok except I can not Recall any knock or O2 readings on the Scanmaster any more it just goes blank Do I need to hook my laptop up and install something for the SM RECALL button to work??
you need to do a pull with more than 3volts of tps i think by default. you can change it in the PL program once you get that setup.
