I just bought a T type with a scanmaster in the car. I notice that on the highway when i go WOT i initially get some really lean o2 readings. 0xx milivolts. then after 1 or 2 frames later it will read the normal rich reading. Is this just a product of the slow frame rate of the scanmaster or is my fuel system not reacting fast enough to me suddenly stepping on the gas pedal? I just replaced the o2 sensor. the car has 42.5# injectors, upgraded fuel pump w/ hotwire kit, TA60 turbo @ 16 pounds of boost. fuel pressure is set to ~50# static. I am completely new to how these ECM's work, is this initial lean reading normal? Thanks for the help.
