Well i just got my new scanmaster and hooked it up...Pretty simple...I thought! Well I put the red wire on the 10amp ignition fuse, black on a ground, and the white I spliced into the orange wire coming from the ALDL. When I turn the key to run the 2.1 comes on and after a couple seconds it goes off then nothing. If I turn the car on still nothing. NOW, I am running without a chip, would this have anything to do with it? Also, if it's not the chip where should I look? Is the orange wire still orange way back at the ecm? Cause maybe it is cut somewhere along the line
