Second Alky. Nozzle Install
salvageV6
Daily Driver
Going to install a second nozzle staged for turn on at 18 or so PSI.
Already have the first one down low on the uppipe bend on the back side of the pipe.
Don't want to locate the second one opposite it with the hose hitting the heat shield insulator.
Want to put the second staged nozzle in the upper bend area near the throttle body.
Any comments or suggestions or anyone running this setup please respond.
Don't want to drill out another uppipe to locate them both up top either. Current one is chrome all my spares are originals.
You moron just slap it in there it don't matter at all.
Only some water and alcohol.
Quit asking stooopid questions. :rolleyes:
Good one! :) I've felt like answering some of my own at times!
I have four aquamists in the pipe. They are opposed to each other and about six or seven inches apart on a horizontal plane. The second stage is nearer to the TB.
I know that this won't be of much help, but at least you know you're not ALONE! :)
I did email Steve but won't get that reply until Thursday most likely. :)
I'm surprised nobody else wanted to change locations on a nice chrome pipe.
I don't think it's all that critical with a staged application.
Of course I will find out soon enough. :D
Thanks for the reply it helped.
Steve replied early so I'll share. :)
It doesn't matter much on the second nozzle.
Up top near the throttle body will be fine for a staged setup.
The first moron was right. :D
