Hey, I have a problem with my tranny starting off in 2nd gear occasionally. If I drive the car with a fairly light foot the trans will shift nice and tight 1-2, 2-3 and then start off in 1st at a stop. Adjusting the TV cable responds well with a click or two forward making the shifts sooner but still firm. The tranny is a built unit with higher pressures so adjusting the TV the normal way plus a couple of clicks foward seems to get it to shift right. When I get on the gas hard the trans shifts great through the gears but then will occasionally downshift really hard into 2nd when slowing down and at say 25-30mph, then start off in second from a dead stop. I have found that stabbing the throttle to the floor really hard for a spit second seems to relieve the problem and the tranny will shift fine until it gets hung up again. Also when this happens I shift manually to get the tranny to pull in first, I will get on the throttle 3/4 to full pedal and it will hold first for a while shift hard to second hold that gear for awhile then finally bang third and will almost never find OD even at 75-85 mph until I stab the throttle to the floor for a spit second and it shifts to OD. Please help...Thanks
