Belt
I happen to be an expert on this subject, and I can prove it by the line gouged into my A/C compressor pulley. The GN belt is about 63.5 inches. The TTA belt is 1603.0 mm (about 63 inches). If you use the GN belt it will work well for awhile, then slowly it will stretch and get the tensioner pulley to rub on the A/C compressor wheel. It probably has to do with the tensioner having 108K on it as well.
I bought two genuine GM belts on GMpartsdirect.com, but when someone else tried it they said that all were sold.
Try and get a belt that is 63inches long. Usually the length is in the part number. For instance the 635k6 is a 63.5 inch belt with 6 ribs (GN belt).
You might be able to get the correct belt, but you'll have to call around some.
Ken TTA#1426
