This should answer all your questions: http://www.vortexbuicks-etc.com/tps_adjustment.html
Make sure the sensor arm is on the correct side of the throttle shaft too and that it's moving with the plate. I just went through this and my TPS V wouldn't rise as I floored the throttle, turns out the shaft was on the wrong side
