turbo96max
- Jun 6, 2007
Guys,
I lowered the boost to 15 psi to give me a chance to learn the tuning of the xfi . ultimately im going to take it to a pro for the high boost but I dont want to be tied to a tuner for every little change and for nights where conditions change or at track i need to be able to know whats going on.also working out other things (oil leaks and tires )
Right now if i rip wot and go from no boost to 15 psi i see a lot of knock (knock gauge goes red) as soon as it makes power right at the 13 psi mark.
if i part throttle it and let it build boost like, 10 psi and then go wot (100% tps) theres no knock.
i took about 2 degrees of timing out everywhere but it didnt help and 15 psi on e85 should not really be seeing knock so im thinking i need to either slow down the timing ramp on while 100% tps /boost or increase the fuel delivery as it may not be catching up fast enouh
turbo is a pt70 with a garrett .63 turbine . running xfi 2.0 latest firmware.
any suggestions? what setting should i be looking at ?
