I know this is a longwinded message but i decided I would cram it all into one post and hope some fellow Buick owners would chime in and help me out. I just bought this car and am a little worried about some of the issues it has.
First is the engine noise. The car has excellent oil pressure, at operating temps of 185 with 15-20 psi at idle and 50-60 psi at a 50mph cruise. I dont know much about the engine other than it was rebuilt about 10 years ago. it has an aftermarket 210/205 cam (not sure what manuf). The sound is almost non existent when cold and slowly gets louder as the car warms up to operating temps. It increases in sound level and speed as the car increases in RPMs so much that i can hear it from inside the car over the sounds of the exhaust.(full exhaust without muffler or cat with stock DP.) It sounds like rocker noise but it has stock rocker shafts in it. The car has 189,000 miles on it. Can the rocker shafts wear out causing noise, or is it possible that is has the noisy clicking comp cams lifters i have been reading about???
Second is cold idle. The car had a bad MAF sensor and would not idle cold. I tested by disconnecting the sensor at idle and the idle smoothed out. Today i replaced it with a known good sensor purchased on the board, reset the computer and took it for a cruise of around 15 miles. The car ran great and the O2s were back up to decent numbers at idle with no more MAL codes. The car has a heated O2 sensor in it that did throw a code but i have not replaced it yet. tonight after work i fired the car up and it would not idle again. It did not throw a code but while it was idling the O2s were cycling down below 100. I held the car at about 2000 rpms to warm up and when i let off it took a second searching and then smoothed right out idling and O2s increased to cycle up into the 6-700s and drove fine after. is this an effect of the bad O2 sensor or possibly a vacuum leak?
Third is the temp readings im getting. The car is equipped with a scanmaster and an AutoMeter Sport comp mechanical temp gauge. The scanmaster reads approximately 10-15 degrees cooler then the gauge. Are there 2 different points temps can be read from and if so which one should i go by?
Fourth is the Air Temperature sensor. All of the ATS i have seen are in the MAF pipe before the turbo. This car has the sensor installed into the up pipe coming off of the FMIC right before the throttle body. Is this a normal thing or should this sensor be moved back to the stock location?
Lastly is the transmission. It feels like it has a shift kit, i know it has a stage right transbrake and a 3000 stall non lockup converter. Tonight i took it for a ride and the shift 1-2 was crisp along with 2-3. It seems however to search for overdrive sometimes while driving and wants to downshift very easily. Earlier i drove it and it was searching so quickly it felt like a miss in the engine. Then tonight at one point it banged into overdrive at a 55 mph cruise. the shift was so hard it felt like the trans was going to jump out of the car. That was the only time it has done that in the 5 days I have had the car.
I hope to look into some of these problems myself but unfortunately i work 14 hours a day 7 days a week at my restaurant and only have about 2 hours at night to drive the car so i am relying on the wealth of knowledge on this board to help me out and try to narrow my options down so with the little bit of time I have each day, i can look at more specific things rather than wasting time chasing something i do not need to.
Aside of these issues the car runs great! It pulls very strong, shifts well under power, and at 15 psi boost, has no KR at 42 psi fuel pressure. I will add that I live at 4,500ft of elevation and only have 91 octane at my disposal.
Thank you very much for any help you can give me!!!!
I went out and took some SM readings to help. Im sure the neighbors loved that at 12:45 at night!
CLT - 180
O2s - 100-700 cycling at about 2 sec intervals
AF - 05 steady
L8 - 35-39
bat - 13.7
INT - started at 142-149 and dropped to 120-130 as it warmed up
bl - 135
ATS - 91
RPM - 775
TPS - .48
IAC - 09-11
cc - 11-249 steady climb through the range and then back to beginning.
Thanks again for even reading this far!!!
CLT - 180
AF - 05 steady
L8 - 35-39
bat - 13.7
bl - 135
ATS - 91
RPM - 775
TPS - .48
IAC - 09-11
