shaft rockers for iron heads
turbo6man
Hello. I'm looking for some shaft rockers for a stock iron cylinder head.
Thanks for looking
stock shaft and rockers? for stock head
or roller rockers for stock head ?
I ask because ever thing in you sig spelled looking for rollers not OE stamped.
I'm sorry for not being clear. I'm looking for shaft roller rockers like t&d or harland sharp. Etc...
Thank you
Thank you
Roller Rockers
FYI,
If you’re keeping it stock lift, 1.55 are the stock factory ratio
The roller rockers also are available in 1.60 & 1.65 ratio
Thank you I would entertain any rocker ratio as I have not spec'ed the cam yet. The motor is a stroker wirh a rjc girdle and ported iron heads and a comp turbo 6871 hubless compressor wheel
