Tim Cucci
- May 24, 2001
Finally got my car back for the 3rd time from the tranny shop after rebuilds. 1-2 shiftpoints were extremely late before the last trip in the shop. I ordered new gov. and had them install in the last adventure with them. They also put in a shft kit and super servo and alto wide band in the last trip. The tranny shifts extremely hard now and shifts from 1-2 at 4300 rpm.Speedo is wrong.
I pulled the gov. out and they did not swap the green gear with my orange orig, GN gear "I told them to swap it and they had direction to swap it". I swapped the gears and corrected the speedo problem.
I have verified that I have the correct gov. and brf valve body. What can I do to get the 1-2 shift points back up around 5200-5300 rpm?
I am not taking it back to the tranny shop!! I'll do it myself!!
I don't mind the firm upshifts but really don't like the downshift clunk that I assume is caused by the super servo. I think I want to also swap it back out with either the th200 or stock GN servo. Will this correct the downshift clunk?
I also have a brand new seperator plate if I need to use it to correct any of this mess.
Tim
Tim
