The most knock you get is 1 thru the gears? If so,keep going up a lb. at a time. Just keep going until until you see a steady knock at aout 4 or 5 degrees. That's what i'd do,and do and do and do!!! The only thing that seems to break are valve springs. That's my engine,not saying that will happen to you. But,remember the higher you go-you need to pay more attention. GOOD LUCK.
