Shurflow surge suppressor
I started to setup my Shurflow system this weekend and decided I really did not like the surging. The diaphragm pump seems to surge slightly no matter how high the rpms are.
I decided to experiment with a small intermediate tank to see if it would smooth things out. It turned out better than I imagined and the setup is really cheap and easy to assemble. I used a Cullagan Marine water filter enclosure that I got at Lowes for about $19.
See Pics here
The enclosure is completely plastic and is rated at 125psi (it feels like it will support way more than that for short periods of time and It held fine for me at over 220psi).
Anyway, the spray and pump are both very smooth now, the surging is completely gone, even at low RPMs and pressure. The new problem is finding a solenoid and pressure switch that can hold the incredible pressure this thing can produce. I ran it wide open and it hit 220 psi. My pressure switch started to leak all around the seams (I use this to trigger a LED on my pillar pod). After removing that, the solenoid body blew apart and an incredible stream of water hit my ceiling.
Anayway, I thought some of you guys might be interested in this.
See Pics here
