I have a 1985 GN and yesterday after I picked up the car from the muffler shop I noticed that as I stepped on the gas on first gear it build about 16 LBS of Boost but the car seemed very slow like it was BOGGING DOWN and not going anywhere, it took too long to shift into second gear, the Boost was there but it was still too slow on second. Before it would spool up very fast and it took off. Now it burns the tires real good but after that it hesitates, you can feel it like if it wants to go but it is hesitating. Can anyone of you guys that have experience give me some pointers as to what do you think it may be. I have AVGAS and I just dumped two gallons of Xylene in the Gas Tank and I will try it again later. NO SCAN TOOL THANK-YOU
Mods: Ported & Polished Heads, 3 inch Up/Down Pipe, Cold Air Pipe with 18 inch Cone K&N, Blue Tips Injectors, Postons 93 Octane Chip, Adjustable Fuel Pressure Regulator, Adjustable Boost Acctuator, Enhanced Turbo, 2800 Stall Converter, 390 Gears, 3 Inch tubing with 3 Inch Flowmasters with an X Pipe, Postons High Performance Fuel Pump (Soon to be hot wired and a new Adjustable Fuel Pressure Regulator and a new Chip from Joe Lubrant).
TOYS: 2002 True Blue Lightning
1970 Plymouth GTX 440 Six Pack
1969 Roadrunner 510 Cu Inch
1993 Z28 with several bolt ons
