small buck
wicked6
After making a high speed run to test alky turn on point. I noticed that the car started to buck while cruising. It was a small buck that was noticable and the rpms did not go up and down with the buck. Is this a tranny/TC issue???
It could be...but then again it might not be. :p Realistically, there isn't enough info in your post for us to make a determination.
Well, I did not notice anything on the way home. If it does return, hopefully not, I will try to elaborate more information. But what more kind of info would you need.
In the future, when the tranny goes which more than likely will happen. I am going to get a tranny from Bruce and replace the AC TC which I do not like with a 9x11.
Kinda Late, but......
My problem sounded the same as yours and it turned out to be a bad T/C solenoid.
John C.
