SMC control box
turbojitsu85
I have my system to turn on at around 14 or 15 psi and it works well. The only problem and it is a small problem is that after it sprays the first time and the yellow light goes on it stays on but dim. The alchohal will turn off like it is supposed to it's just the yellow light that stays dim. Has anyone had this problem and if so how did you fix it. I would hate to dismantle the whole system and send it back just because the light wasn't working proprerly.
Try taking advantage of one reason u BOUGHT an SMC kit. Customer support! :D Steve will steer you in the right direction or fix the problem entirely!
problem solved?
Turbojitsu:
Sounds like one of the infamous bad pressure switches! Call me for a free replacemrent.
