SMC problems
tquick87
So i installed a smc alky kit and everything worked for a little bit but now it doesn't spray alky. The power light stays on and when the test light is pressed the car stumbles so the pump is working. Also i tapped the boost line into my boost gauge which is also still working. Everything is wired up correct so i'm at a loss. Any help is appreciated.
Tyler
Older kits used a hobbs switch inside the box. Newer kits used a 2.5 bar map. Aside from an issue with hose getting pressure to it. Dunno. Maybe mess with the turn on setting and put it as far counterclockwise to have it spray as early as possible.
If the engine stumbles, it's being sprayed.............
Take the nozzle out, and see what you get.
Figured it out. Had to turn the max down from 22 to 15. Im going to play with it some more because i dont need max alky at 15lbs
