M
		mark p. liner
Guest
i have enuf miles on my engine to start a wot tune.so i hooked the otc 4000e up and off i go. for some reason at wot the car wont shift out of 2nd,the 1-2 is at 4500 rpm like i want it to be. at 4500 in 2nd the car just hangs in there.so i tryed to keep it at wot for a few sec. in 2nd to see if it would ever shift,all the times b4 i would just let out because it would not shift, and no dice, the tach. was just fluttering around 4500 rpm with no shift. the crazy thing is that if i give the car 98% throttle it shifts fine, its just when i put it to the mat it goofs up. i know the trans. is good,not slipping or anything. it rips 2nd, and bangs 3rd and od hard.it is a stock 87' trans. with few miles. i played with the tv a few times and did not help. it did not do this a few years ago b4 i put the new engine in it. please help
