65skyturbo
- May 8, 2008
How much tolerance is there with the servo pin length? I installed the Sonnax super servo today which comes with a new servo pin. They recommend the length to be .110". Mine installed at .132". Does the .022" fall within the recommended specs? The only way I can see to remedy it is to weld the tip and then grind it down to spec, but is .022 worth it? Thanks for your input.
