Spark plug wires
TurboTer
Zap! Commander
Can someone please post a detailed picture of where each spark plug wire leads to? I have old wires on now (I'm replacing them with 10mm), and think surely that the current plug wires lead to the wrong plugs. Thanks for any help in advance!
Drivers side of the engine starting front to back, the plugs are : 1,3,5. Pass. side front to back are: 2,4,6. Then just match them to the numbers located at the base of each post on the coil pack.
Your numbers on the coil pack will match if it's not been turned around.:D The 1, 3 and 5 bank numbered on the coil pack, should be closest to the fire wall.
2, 4 and 6 will be facing the plenum. It doesnt matter if the coil pack has been turned around it will still work.
Oh boy, I need help! First of all, there are no numbers at all on my coilpack. I tried as best I could but after I took off the old 8mm wires and replaced them with 10mm wires and started it up, I had MASSIVE backfiring! I need a link to a detailed pic of the engine, showing all the wire locations. Please help!!!
Originally posted by Iceman
Check your e-mail
Thanks a lot, that pic was great. :) But...still was backfiring badly. So I took off the 10mm Magnacores and put back the old 8mm's on and it's fine. Hmm, bad plug wires perhaps? I bought them used.
