Speed Pro CS-1016R
boostmaster
HOW GOOD IS THE SPEED PRO 204-214 CAMSHAFT AND WHAT KIND OF GAINS AND IDLE QUALITY COULD I EXPECT OVER THE STOCK CAM.
:D awsome cam
with stock converter it idles at 12-13 inches of vacuum and 15-16 in park
only time i can hear it has a cam in it is when first fired up cold.
its in a i/c motor but as far as idle and stuff it should be the same.
i wish i had it in my hotair motor but i have the 194-204 in the hotair motor and it worked real good also
both my cams are actual speed-pro cams
as far as gains over stock cam it should be a big difference
for drivability you dont even know its there im gettin a little less milage dthan with the 194-204 but im still in the mid 20's on the highway and driving normal around town its not all that bad
keep in mind i now have enough motor to run in the high tens to 11-0's so i cant gripe about a lil mileage
im use to carbed sb chevies im getting killer mileage if compared to them
