Spring Rubbers ?
salvageV6
Daily Driver
Anyone know for sure if any of the big parts chain stores have spring rubbers in stock or for ordering even? :confused:
Need a set for a slightly weak spring that won't be replaced this lifetime. ;)
I know Jegs has them, Mr. Gasket brand, and I can order them online but was hoping a local place had them.
Dood, get off your lazy azz butt and go to Pep Boys and check them out. :mad:
And since you're such a slacker try the truck parts section, they have rubber fixed size and the steel bracket adjustable ones to raise or lower the car depending upon how they are installed (same kit).
They are made for the rears but probably would fit in the front. :cool:
$10 for 2 rubbers, or two brackets.
Hope you don't take as long to install them as you did to find them. :p
