Dec 20, 2004 #1 N NOT FAST New Member Joined Oct 14, 2002 Messages 93 What kind of ignition setups are you guys running? I got a off center stage motor.
Dec 20, 2004 #2 T TurboTR sprayhead Joined May 25, 2001 Messages 1,220 Either the stock setup, if you also use the stock crank and cam sensor scheme, or a distributor based setup. Basically whatever you want can be made to work, somehow TurboTR
