Try a NGK BR7EF....or if you don't mind spending a little money try the Denso IT 22.....cold, extended tip or the IT 24.....really cold, standard tip. A NGK TR6 might also work, I know it would run great, but I'm not sure if it would be cold enough under boost.
It is an extended tip, fairly cold plug, it is one of my favorites in other applications.
Either the NGK's or the Denso's should run better and have better throttle response than the Autolites IMHO.
Dale
