Stall question
Sal Lubrano
If a converter stalls at 2800 at 0 psi and 3600 at 7 psi. What stall would you call this converter??
Hard to tell without a transbrake. Engine performance has an effect on stall speed as well.
as stated above....it's hard to tell exactly what stall it is, most people rate there stalls for a certian hp application. for ex. a converter that stalls at 3500 on a 500hp engine...that same converter will stall like 4000 or so on a 575-600hp car.....you get the point. but the converter you are describing sounds pretty loose...like 4000-4500 stall or so. assuming you have a turbo 6 motor to it.
