Starting Problems
84GNTTYPE
Senior Member
My car has been in the shop all winter, its been ran once or twice to move it around, but no actual driving. The other day the guy moved it, but said it was chugging pretty bad, then when he went out later to restart it, it wouldn't start. I haven't been able to make it run since. I tried adding gas. I checked the fuses, they were all fine. The only thing I can think of is the fuel pump is bad, so I'm going to check that tomorrow. The guy swears he didn't touch anything under the hood. Any help would really be appreciated. Thanks!!!
fuel pump could be it...my car sat in a paint shop for 8 months, they moved it around about 100 times...the day I pick it up, I backed it outta the bay, put it in drive, and the pump decided to call it quits!
I checked the fuel pump today, it was fine. I think the bad gas probably gummed up somewhere. Any ideas of where to check first?
yea um.. fuel filter.. injectors..
put a can or two of berrymans 12 in theer along with some 93 should help some.. might as well whileyoure at it. pumpa ll the crap gas out into a bucket.. use it to kill some ants or something..
