Stock Concert Sound Ii Radio
blipmode188
I have the stock radio in my 86 GN an the radio has two problems
1) the presets all loose their settings when the car is turned off along with the clock looses the correct time.
I think I read on here that it is on its on power circuit seperate from the radio ?
I have checked all of the fuse's well except 1.
There is some sort of plug and red wire going approx to the middle of the fuse box with a fuse directly above it that I cant get to.
I have tried to pull this mystery connection out with no success and cant access the fuse directly above it.
Anyone know what that wire and connector is ?
I think the wire is red ?
2) The cassette player will not play. You can put a tape in, the tape goes in
the lights light up but the cassette is immediately ejected.
Same for an IPOD adapter cassette. As soon as I put it in, it immedieately ejects right back out.
Any clues on the above ?
Thanks Steve
I had mine repaired...
PM me for the info on where to send it for repair, if you want.
