87GN_ponykillr
Buick addict
- Nov 25, 2003
Stock parts for sale: Please don't PM me instead, EMAIL all questions to zl1power69@yahoo.com. I'm not on here much. Prices are without shipping and paypal fees. Offers considered.
Pics:
Turbo Buick parts FS pictures by Undercover87T - Photobucket
- Stock 109 Jasper long block. Apx 80k. Motor was in the car when I bought it. It would run and drive but previous owner ran low on oil after swapping oil pumps and spun #1. I did pull the pan and put new bearings in but still had some noise (bad timing chain, possible piston slap #1). I have photos of the pan off upon request. Other than that I have not had the valve covers or heads off to see if anything else was damaged. If it doesn't sell soon I may pull it apart myself. No current pics as its currently sitting in a garage about 30min away. Can get some on request.
Info: 20/20 crank (#1 hand polished more as an attempt to fix damage from spun bearing), new 20/20 bearings, stock rods/pistons, stock complete 8445 heads, stock valve covers, timing cover/water pump/high pressure oil pump, stock oil pan/pickup, stock balancer, stock flex plate. Missing some things like timing cover bolts, valve cover bolts, etc as I was swapping parts over to my 4.1.
$350, really not wanting to ship this.
- Stock turbo with down pipe elbow, no play or smoke, needs to be cleaned. May have been rebuilt once before. $150
- Stock down pipe with ATR converter $125
- Stock intercooler with scoop and pass side bracket $100
- Stock EGR valve $20
- Stock EGR purge solenoid (mounts to driver's side valve cover) $20
- Stock plenum $20
- Stock rad. Had slight leak at drain otherwise ok. Removed to upgrade to GN1 3 core. $75
- Stock efan $30
- Stock coolant and washer bottles $10 each
- Stock air intake $60
- Stock older NAPA refurbished MAF worked fine $65
- New unopened ARP rod bolts $75
- Stock rear sway bar $30
- Stock upper/lower control arms $75
- Pair of driver quality chrome headlight bezels $80
Pics:
- Stock plenum $20
- Stock efan $30
