STF420@comcast.
- Oct 6, 2003
Hi, I have a problem I can't seem to figure it out. At low RPM it builds boost fine then the boost falls off as RPM increases. I can get 19lbs in 1st & 2nd but by the end of the gear it is down to almost 16lbs. When it shifts into 3rd it goes to 20 to 21lbs and holds pretty good. The car runs good 12.30's @ 108.5mph. (Stock turbo, KB Big Boy, Ported iron heads, 3000 PAT's LK-up, Tho I have not locked during a run yet. KB Hi-LO Pro chip, Slicks, Ford Super coupe injecters, Wastegate housing fender dump.) I have tried bleeder valve. Grainger valve. I can't seem to get high boost to hold in the lower gears without getting way high (TO HIGH) in the upper gears. Am I running out of Turbo (Not enough CFM?) Any help would be appreciated.
Thanks, Mike
Thanks, Mike
